Re: Just to get it started?
Posted by Tom Windsor on March 22, 2008 at 21:48:59 from (205.188.116.73):
In Reply to: I need some wiring help posted by Mike CA on March 22, 2008 at 20:28:23:
If that is all you want to acomplish at the moment, run a jumper wire from the negative side of the battery to the negative side of the coil...then wind it up.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
