Posted by John T on March 29, 2008 at 20:46:29 from (66.244.97.31):
In Reply to: 10 ohm resister posted by 160dan on March 29, 2008 at 19:49:35:
An ohm meter will tell what it is, good chance its a diode or maybe an in line resistor. Ohm it out real quick n you will have the answer. It would wire somewhere between the coils high input terminal or the ign switches IGN output terminal and the lil No 1 side alternator terminal...Ignition ballast resistors are also used when its a 12 volt tractor with a 6 volt coil, they are around 1 to 2 ohms or so. An idiot light could also be used for the alternators excitation instead of a resisotr or diode.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
