Here's a backside view of a switch as on your B. The field resistor is the wirewound unit at the bottom. Seems to me the correct resistance is 3 or 4 ohms - however I'm only going from memory here...
However if it were mine I'd replace the cutout relay with a voltage regulator. The V/R will do a much better job of maintaining the battery, and it will eliminate the need for the field resistor.
I believe the fuse is an SFE 10 (glass tube type, 10 amp). However later letter series and Supers used an SFE 20 (20 amp) fuse - that's what I recommend.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
