Re: Another 856 question....This time about the shift linkag
Posted by the tractor vet on April 05, 2008 at 16:00:47 from (76.212.238.60):
In Reply to: Another 856 question....This time about the shift linkage posted by Dan Swanson on April 05, 2008 at 14:14:28:
Well first off pull the cowel and the kick plate down by where your feet are Two bolts with 9/16th heads and start looking everything over and see what all is needed . On that tractor even the smallest amount of ware even on the headed pins means a lot of movement at the shifter . Not word to the wise here get the correct pins for the rod , yea i know ya can get the same pin from just about anywhere NOT. as the cotter pin hole will never be in the correct location BTDT . Look the shifter levers over and see how much ware is there and replace any parts needed . Don't just try and start adjusting this and that as then you will have one big mess.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
