Re: NEW IDEA TRANSPLANTER T-73
Posted by SuperA-Tx on April 10, 2008 at 20:09:39 from (4.90.51.50):
In Reply to: Re: NEW IDEA TRANSPLANTER T-73 posted by Bryan Jones on April 10, 2008 at 15:39:06:
There isnt a round part on top. It has a flat metal plate and a gasket on top. Inside the valve will be a spring and brass ball. There is a square rod on the front that usualy rusts up but it comes loose easy if you soak it in oil. Might take a few hits with a rubber mallet too. Then there is an arm that pivits that lifs the square rod. To hard to explain it all here.
They were all horse drawn as far as I know but later models you could get with a motor or to use with a tractor. If you got one to use with a tractor then the seat on the barrell didnt come with it. I also think that is why the lift arm for the floating sub frame was moved to the front where the planters lifted the sub frame instead of the guy on the barrell. Yours have the one lift arm by the barell on the right hand side?
I can copy a book I have that a friend here sent me and mail it to you. In fact I have two differant books depending on what kind you have.
Click on the email link and send me an email and we can go from there.
Randy
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
