Re: matching tags
Posted by Janicholson on April 14, 2008 at 13:26:52 from (199.17.6.122):
In Reply to: matching tags posted by TravisB on April 14, 2008 at 09:38:22:
Though not a rule, up until about the early 40s The numbers matched. As production was moved to differing assembly lines, and models using the same engine were introduced, there was good reason to let the two drift apart. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
