Re: I like the grease on plywood idea!
Posted by Carden on April 28, 2008 at 03:27:07 from (74.33.241.19):
In Reply to: Re: Axle housing seal replacement posted by Owen Aaland on April 28, 2008 at 01:49:22:
Sounds like the easiest option to me. Any idea how far that will slide out before the bullgear stops it?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
