If you are changing the gear lube you should drain the belt pully seperately using the small pipe plug on the bottom of that casting. You can refill the belt pully thru the plug in the top of that casting but it will gradually refill thru oil lines from the transmission. If your going to use the PTO for a mower or such I would pour a pint or so into the belt pully casting so it is lubricated right away. Oh, and you should change the lube in the final drives also if it hasn't been changed recently. Dave
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
