A lot of A's had no electric to start with. Ig nition was mag. If your has a distributor it could be 6 or 12 volt. 6 volt generators are available and easy to install. I believe I see the bracket bolts in the picture. Soo if the beast is 6 or 12 volt and or distributor or mag and is 112 or 5 volt is all information needed to properly advice you. As I don't see a battery I have to assume its a 6 volt mag spark started by crank or if it has a starter the battery is somewhere else. I love it when a plan comes together. Nuff said Henry
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
