Posted by Andy Motteberg on May 14, 2008 at 22:34:02 from (4.143.217.30):
Hi all, I think I've done about everything on the 1944 Farmall H tractor to try and get it to stay running. I put oil in the cylinders today and did a compression check, Cylinder #1 has about 35, #2 Cylinder has about 65, and #3 and #4 have about 90. The valves were way out of adjustment so I set them correctly, same problem, still won't run. I cleaned the manifold, same problem. Me and Dad worked on the H a lot today and we can't get it fixed. We are guessing that the piston rings might be stuck, so I'll be replacing the piston rings next. I think this engine should have more compression because when we had the cylinder head off, we seen it has aluminum pistons and a high compression gas cylinder head.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
