Re: H trans gears
Posted by Owen Aaland on May 23, 2008 at 22:47:28 from (65.165.246.101):
In Reply to: H trans gears posted by Calif. Farmall on May 23, 2008 at 16:25:02:
Removing the top cover is not necessary to replace the input shaft bearings.
Remove the Lift-All pump assembly. Remove the drive shaft coupler. Remove the front flange of the transmission input shaft. Remove the bolts holding the input shaft assembly to the transmission frame. Remove the input shaft assembly.
The two input shaft bearings will be in the assembly you removed. The main shaft pilot bearing can be serviced through the opening where the input shaft was located.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
