Re: Farmall 400 won't start.....+ ground??
Posted by karl f on May 28, 2008 at 15:43:45 from (64.83.221.111):
In Reply to: Farmall 400 won't start.....+ ground?? posted by Dan Anderson on May 27, 2008 at 14:42:34:
the factory ground is terrible on that tractor. if the ground cable is attatched to a battery box bolt that goes through the bottom into the rear cover, it's likely the culprit. disassembly and cleaning may help, but there are too many connections made with that cable and spacer assembly (my opinion). You could try running a ground cable all the way up to the starter mounting bolt; temporarily with a jumper cable.
also if you have the bolt on battery clamps, throw them away and get soldered/crimped ends. THe bolt on ends are designed to get you home. we've had nothing but battery trouble on machines where bolted on cable clamps are used.
karl f
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
