Well with out putting a pressure gauge to it atleast you have know idea what you have . Now the best way is have the system flow rated by a mechanic that has the proper test equipment as this will save you time and money . It maybe the pressure regulator or it may be the main hitch pump or it may be both. If it needs both then myself i would update the pressure reg. valve to at least the 2100 lb. valve . Some of the newer equipment has smaller lift cylinders and needs more pressure to lift it. It would take me about a half hour to 45 min's to run the flow rate test by the time i got the oil up to temp.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
