Posted by Oregon-ized on May 30, 2008 at 21:31:14 from (70.193.239.129):
In Reply to: int fcub posted by Oregon-ized on May 29, 2008 at 21:57:29:
WOW! Lots of gr8 info so let see yes the mag does "SNAP" when turned over I disconnected the kill wire and got a weak jolt from the coil wire so Im thinking it's probably points need some attention just have to find 'em all compression sounds good all four cyl need to work on the carb a bit stuck float shouldn't be too bad
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
