Posted by Nebraska Cowman on June 03, 2008 at 04:24:35 from (65.165.16.237):
In Reply to: dual fuel carburetor posted by FMS-KS on June 02, 2008 at 21:05:22:
The only difference between the dual-fuel or distillate carburetor is the size of the jets. And after all these years it probably has gas jets in it anyway. Yes, the icing is normal and in most conditions doesn't hurt anything. In some conditions it will ice up inside and choke the tractor til it won't run but if you let it set a few minutes the heat from the engine will thaw it enough it will run again. In feeding with a gas tractor in the winter I've only had it happen once on an extremely damp and frosty morning.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
