Posted by Janicholson on June 03, 2008 at 09:00:54 from (64.83.197.176):
In Reply to: NAPA 12v solenoid posted by plh_in on June 03, 2008 at 08:35:42:
Yes. Your A never had one, so the one you buy will be fine. If it has 4 terminals, 2 small, and 2 big, the small labled "S" is the start switch terminal to make the starter turn. The ine with an "I" on it goes to the non-distributor side of the coil to assist starting voltage to the coil when starting (bypasses the ballast resistor). If you have a mag, or 6v or 12v system W/O resistor, ignore the "I" terminal. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
