Posted by mkirsch on June 04, 2008 at 16:34:37 from (64.80.110.50):
In Reply to: IH #8 Plow frogs posted by MAGMAN on June 04, 2008 at 12:10:47:
MAGMAN said: (quoted from post at 12:10:47 06/04/08) I have a brand new set of moldboards and points , I know there IH but they dont match my plows But I do have 3 or 4 sets of IH plows here, In Central NY.
MagMan
Hey Magman, you don't have any spare coulters around do you? Need 1-2 for my #60 plow so I can turn up some sod. Figure at least one for the rear bottom so it leaves a nice furrow for the next pass... Pullin three 14's with a 5220 Maxxum so power and traction aren't an issue.
Tom, here's a quick primer on plow parts, assuming a conventional plow. All directions are looking at the plow from behind:
1. Beam - The heavy cast piece that connects the bottom to the frame.
2. Bottom - The sum of the beam, frog, landside, moldboard, shin, share, and point.
3. Frog - The underlying frame for the plow bottom. All other parts bolt to it.
4. Landside - A wear plate that rubs against the side of the newly-dug furrow to keep the plow moving straight.
5. Moldboard - The large piece that turns the soil over and drops it in the open furrow to the right.
6. Shin - The leftmost piece of the moldboard. Early plows had a one-piece moldboard, but the Plow Chief and later Super Chief designs broke it down into a moldboard and a shin because the shin wears out at about the same time as the point/share, but the rest of the moldboard wears much more slowly. You can go through several shins before wearing out a moldboard.
7. Share - The lowest part of the plow bottom that digs the soil free across the width of the furrow.
8. Point - The very leftmost tip of the share. The point pulls the plow bottom into the ground. On the Plow Chief design, the point is a separate piece. Most bottoms have a one-piece point and share design because both wear out at roughly the same time anyway.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
