Re: worm gear
Posted by Steven f/AZ on June 04, 2008 at 19:05:50 from (24.121.155.84):
In Reply to: worm gear posted by ryanroth on June 04, 2008 at 08:21:38:
The nut on the end of the shaft merely holds the bearing on.
Remove the plug, slide the shaft out of the u-joint, and screw it right out of the upper bolster/gearbox.
I've packed mine full of grease because the oil just slobbers out and makes a mess.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
