Posted by RJV on June 14, 2008 at 03:30:42 from (75.179.27.97):
Just to confirm, I know the original manual says 65 ft. pounds for the A head, was there a bulletin that came out saying torque should be 80 foot pounds????
Also found out that not all A head gaskets are the same. Some As came with the 123 CID engine and had a water pump. This head gasket has smaller holes for the water passages. I got one of these gaskets from the shop and Im glad I noticed the difference. When buying a gasket, if your A doesnt have a water pump and is the 113 cid engine, make sure they give you the correct gasket.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
