Posted by Wisconsin_Joe on June 18, 2008 at 10:36:21 from (68.22.71.89):
Here goes,
I have an H that has been converted over to a 12v system. Last year I replaced the alternator and all the wiring which was all ratted up and put on some heavy duty battery cables. I also put in a new battery as well. I store my tractor over the winter so I added a trickle charger to maintain the battery. This winter I went to start it and it turned over really slow and them gained momentum and started. The battery seemed ok so I was leaning toward a tired starter. But last weekend I noticed the trickle charger would not kick off and was constantly drawing to charge. I popped the battery caps and noticed the positive side was low on water. I figured I had found the culprit and it wasn"t my starter. I filled and charged. Next day I just wanted to see if it would turn over stronger. With the spark off I hit the starter button and water from the positive side of the battery came squirting out as the tractor turned over but it was a stronger turn over by the starter. Popped the caps off the pos(+) side again and water was low. I figure the battery is being overcharged. How do you stop the alternator from overcharging the battery on a 12v conversion or is there something else wrong here? Thanks in advance
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
