Posted by Janicholson on June 22, 2008 at 17:48:23 from (68.115.113.25):
In Reply to: Electric funny stuff posted by Idaho Ron on June 22, 2008 at 17:33:14:
If you are using a DMM, the meter is probably reading noise and not true volts. Using an analog with a needle, is probably best. 14.4 volts is correct, so the issue may be a short sircuit somewhere, or a battery going bad. Test the battery cell specific gravity if possible. Use an analog meter, or a fluke (expensive) DMM. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
