Re: M Clutch Throw-out Bearing
Posted by John M on June 28, 2008 at 18:01:26 from (209.213.22.170):
In Reply to: Re: M Clutch Throw-out Bearing posted by F-Dean on June 28, 2008 at 17:04:57:
Drop the pump, Ill bet one of the pins out that holds the 3 fingers on the pressure plate has fallen out. With the right prying, you can put it and a new cotter pin back in without pulling the clutch out. I had that happen a couple of times to me.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
