Re: Farmall C Side Dresser Drive Sprocket
Posted by mazemeister on June 29, 2008 at 17:50:00 from (24.188.81.230):
In Reply to: Farmall C Side Dresser Drive Sprocket posted by Matt Compton on June 29, 2008 at 05:46:53:
isn't that side dresser designed to be run off a sprocket bolted to the end of the brake shaft? straight C would be different from Super C and descendents that have disc brakes.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
