I think that you have an earlier design. the newer versions used a grounding switch and a wire connected to the "spring ground" as you call it. if you are going for original then i wish you well, i do not have the answer for you; but if you are going for functional, i suggest the wire and switch route, as it is far more reliable than a mechanical cable that can bind, and it will look just like the thousands of other farmalls out there.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
