Posted by Bob on July 11, 2008 at 17:11:53 from (69.178.228.68):
Since posting replies is non-fuctional, I'll try a new thread.
Does anyone in your area have a lathe?
It would be easy to make a driver for the front cam bearing out of a piece of steel stock.
Make it the same diameter as the camshaft journal, or a few thousandths smaller, with a larger "flange" to pull the bushing into place.
To install any bearings farther in, the flange would have to be just smaller than the block's bearing bore diameter, however, to install just the front one, it could be larger.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
