You need to check for fire to the plugs, pull off one of the plug wires and hold it near a good ground or 1/4" away from the plug while someone makes an attempt to start the tractor. No fire from plug wire check for battery voltage to the coil. Should have voltage on both terminals with points open and switch on. Clean the points with some 320 wet or dry. If they're pitted replace them and condenser. If you have a ballast resistor installed between the switch & coil it may be defective.
If there's fire to the plugs you probably have a fuel problem with dirt or rust in the gas tank or gas line. Remove the gas line at the carburetor and see if there's a full stream of gas. Hold a clean container to catch the gas. A trickle isn't enough. If there's a full stream of gas check for a screen behind that tube fitting for a screen. It could be plugged with crud. Be careful not to damage that fitting. Hal
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
