Posted by MN Scott on July 18, 2008 at 16:30:39 from (206.9.216.51):
I have a 756 with the 310 German diesel. Its seeping coolant in the oil from the sleeve seals I think. Its also getting alot harder than it should be to start with oil pressure on the low side. I found a 715 combine 310 engine with low hours for about what a piston and sleeve set would cost for my 310. A total overhaul for my 310 with parts and machineing done right by myself could easily run $6000 to $8000. I have been searching the YT archives and the general leaning of the postings is everything will swap and bolt in except the flywheel. CB ONT installed a D310 combine engine in a 756 gas but did not state what he did to make a flywheel work. Has anyone done this swap and knows what it would take to make it work? Remachine the 756 flywheel or remachine the combine flywheel? Adapter hub? I have not seen the combine engine so I don't know what the crank hub looks like.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
