Posted by Tom Fleming on July 20, 2008 at 18:54:06 from (209.195.155.84):
the parts manual calls for oil guage 18113 DA. i have a 31041-DB which appears to be for an F-12/F-14. are the pressure ranges the same? Where should I expect the needle to be if I am running ok. Right now, running straight SAE HD 30, it is about 1/3 of the total movement, and pointing at the "o" in oil, which puts it about 10 o'clock on the dial. I also notice it takes a minute or two for it to pressure up and start reading.
I have no nocks or noises coming from the lower end, and all the connecting rod shims are still installed.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
