Dan, If all that you work on is the carburetor, the governor should not need to be changed or adjusted until after setting the carb. Top screw - Idle stop. It keeps the butterfly from closing too far. Middle screw that points toward the radiator - Idle mixture. Opening up this screw leans the mixture. Set for highest rpm without making black smoke (too rich). Bottom screw - Load adjustment.
Set them in the order you just read them. Put the throttle hand lever as you want it. There's no right or wrong, it is your preference. I had to set the operating range of the lever up on my '51H because of worn teeth on the plate.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
