It's fun isn't it ? Having a use for the hard work of rebuilding your tractor ? A year and a half ago in the spring I pulled dozens of what I call saplings out with my Oliver and my Farmall M . The trees were anywhere from 4" to 12" in diameter with the vast majority under 6" and most of them were soft maples . I dug some pretty deep holes with the Oliver on some of them while having to pull from many different angles to get them out . I cut the trees about 4' high and hooked the chain as high as possible to get as much leverage as I could to tip the tree to help break the root system on the far side first . Not once did the front wheels of either tractor leave the ground . I did have some bounce in the whole tractor on a few occasions . I didn't start with a tight chain either . I've read a lot of your post's and don't believe you are anything less than an intelligent and maybe a little overly cautious individual . With that said , just think about the end result of any idea you get while using the tractor . I probably do many unsafe things in the eyes of most people concerning using heavy equipment but that's what I do for a living . I use leverage . I'm a crane and heavy equipment operator . It's all good if you think about certain laws of physics and try to work with them instead of against them . I'm not saying the tractor couldn't go over backwards just that you'd need perfect traction to cause it to happen . Not likely on grass such as I assume is in your yard . ...Randy
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
