I need to do this to my F504, the nipple is worn. One way to clean the threads out is to use a Dremel tool with the little cut-off wheel and run around the threads. This will get all the rust scale out and allow the pipe to screw in easily. Also recommend a good anti-sieze compound, Loctite and Permatex both make this.
I read the Dremel tip on this site some time back.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
