1940 Farmall A ? / correct mounting for . . . . . . .
Posted by Brad in Colockum on August 14, 2008 at 19:50:09 from (207.200.116.7):
Anybody know where the correct mounting spot is for the S pull push kill cable knob that runs to the magneto. It may mount on the column to a bolt that holds the throttle on. Or to a little L shaped piece on the back of the throttle housing??
Anyone know or have pics? BKim9166@aol.com
This kill system is cable operated and the wire inside is not electric.
Thanks for your help.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
