Posted by spencer13cat on August 17, 2008 at 18:34:19 from (71.157.170.177):
I was lucky enough to buy a couple of parts tractors one of which had the starter bell housing and flywheel. I have read through most of the old threads regarding this issue. There really isn't a lot of clear info. SO with that I am asking for specifics on just the starter and generator.
1)What was the model or models of the heisler starters. Specifically what markings are on the thing? Also what are the dimensions. Same with the generator assuming these kits had one. Of course pics would be even better, mounted or loose.
2)What other starters work with that bell housing? I have read more than one post where someone thinks M starters work, is this true? Thanks
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
