Chances are very high that you'll need to turn the crank and resize the rod. Once they spin a bearing, unless you have them resized they won't hold a new bearing in place most of the time. The rod journal is most likely scored badly and has bearing material fused to. The bearing material can be scraped off but the journal will still be kaput.
Not going to know for sure until you get that piston out of the bore and a set of mics on the crank and a bore gauge in the rod.
You can either pony up and repair it correctly or put it back together with a new bearing and ride her with a puckered butt for the rest of the time you own her waiting for it to go splat.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
