Re: rear end of H fluid level
Posted by Theman on August 28, 2008 at 04:36:06 from (65.248.77.5):
In Reply to: rear end of H fluid level posted by dancbtmkr on August 28, 2008 at 04:24:33:
The level check plug is on the left side of the transmission case ahead of the clutch pedal pivot shaft.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
