Posted by N.D. Farmall H Puller on August 28, 2008 at 11:16:03 from (69.178.202.105):
In Reply to: #25 Venturi posted by N.D. Farmall H Puller on August 28, 2008 at 06:36:31:
Chad S I am taking your advice and using 1 qt of E 85 and 3 gts of 93 Octane gas in my H. I am wondering which venturi do you think would work best for me. Here is how we are set up 3 9/16ths firecater pistons, 300 head, 300 LP manifold, cam grind & a M carb you had told me a 23 or a 25 would work. We are always short of low end power. Which one do you think. Will take one or the other, how much $
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
