Posted by Red Mist on August 31, 2008 at 12:51:09 from (67.142.130.25):
In Reply to: power steering posted by HENRY E NC on August 31, 2008 at 11:13:47:
Henry: It's going to take a pump and a motor. There were two systems, plus I'm sure a number of home-made inventions. The two systems are Behlen and Char-Lynn. Char-Lynn is the more attractive system as it is hidden under the hood for the most part. It uses an eaton belt driven pump. You'll have to add a sheave to the crank pulley and cut your fan shroud. You also cut the steering shaft. You can buy the system new, or find a used outfit on ebay or perhaps at a big tractor meet.
The Behlen system mounts above the gas tank inline with the steering shaft, which must be cut. It uses its own pump mounted between the distributor and front engine cover. Or, if you have a live hydraulic pump, you can plumb it with a priority valve using the existing live pump. Behlen units are also seen for sale on ebay.
Both are excellent units. Expect to pay $400 to $600 for a used complete unit. Lord knows what you'll pay for a new Char-Lynn. mike
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
