Re: ih 2000 loader
Posted by Jim Becker on September 06, 2008 at 20:06:53 from (71.170.6.245):
In Reply to: ih 2000 loader posted by martin simmons 38655 on September 06, 2008 at 19:38:31:
The #2000 was primarily intended for smaller tractors. A #3000 would have probably been recommended for a 706. But IH did consider it a valid combination. So it should work OK but you could probably tear it up badly if you put your mind to it. You just need to come up with the right mounting package.
Lift height on that tractor would probably be around 150 inches. If it has single way cylinders it will probably lift 1,300# to full height. With two way cylinders it would be around 2,000#.
I can't help you on finding a bucket.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
