Bill Bowen said: (quoted from post at 14:19:54 09/07/08) I have seen a post about this,but I don't remember how far back.The leak is at the transmision end.I have removed the connector from the trans to the pump.Do I just remove the three bolts on the cap on slide it off the drive.Also there seems to be a drain plug just below the access place.Would I drain the oil there or at the plug in back.Thanks for all your help on this rebuild project,got it runing but now have leaks where I didn't have before. Bill
You are correct, just remove the three bolts, remove the seal retainer, knock out old seal install new one and bolt it back together. There is no need to drain the oil in the transmission, just park the tractor so that the front is facing uphill or jack the front up a few inches and put a block under the front wheels, make sure you block the wheels so that it won't roll!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
