I had that same thing happen to my H when I was harrowing last spring. I took the cover off under the clutch and was able to see up inside. There is a shaft inside of that little area behind the bellhousing, that turns kind of like a drive shaft in your truck. There are, if my memory serves me correctly, 4 bolts up there on that shaft that hold it together. All of mine were loose. I tightened them down good and tight, and the noise has not come back since. Boy I sure was scared, but it has held together for over a year using it every day for at least an hour or 3, sometimes all day long! Good luck!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
