Re: How Do you time a M ??
Posted by Oldtractorfun on September 13, 2008 at 18:05:33 from (70.24.100.201):
In Reply to: How Do you time a M ?? posted by Oldtractorfun on September 12, 2008 at 10:58:28:
Still not sure where that bolt for the tab is suppose to be that will let me turn the whole distributor. I do see 2 bolts at the end of the distributor itself where it bolts on the shaft but that all seems solid.
Gave the rest of the steps a try and everything seemed to be linned up where it should be. Had to clean the points up some and set them.
Took the M to an antique tractor pull today and came in second in the 5500 lb class. Lost by 2 feet to a Farmall 504 so the M is not running too bad.
Haven't checked the plugs yet, will do that tomorrow and see what they look like.
Thanks for the replies and help everybody.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
