Posted by Janicholson on September 21, 2008 at 16:02:30 from (66.173.50.157):
In Reply to: Re: Early M runs hot posted by Eric Bergstrom on September 20, 2008 at 21:44:15:
The thermostat is in the bulging cast iron "blob" at the top radiator hose. It comes apart rather easily. New gaskets can be cut from NAPA .030" gasket paper by using a ballpeen hammer and tapping the gasket material gently all around the edges of the removed half of the casting (including the holes) the resulting gasket is perfect. Place the thermostat in a coffe can (or the like) and heat it on the stove. Use a candy thermometer to check the opening temp. If the water boils it is toast (in this case).
Other issues are gow much water will flow through the radiator and out the bottom hose (disconnected) if it is restricted, it will flow less than you can pour in the neck. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
