Kevin, the TA is exactly what you want to use to pull out of an intersection. You can start out in 5th TA from a dead stop unless you're pulling a really heavy load, accelerate quickly, and then go to direct to get to full road speed.
The alternatives:
1. Start out in 4th, creep halfway into the intersection, miss the shift, grind the gears, and roll to a halt in the middle of the intersection. Start over.
2. Start out in 5th direct, stall the tractor, slip the snot out of the clutch to get moving, or hop across the intersection.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
