Re: hard starting IH 560
Posted by the tractor vet on October 01, 2008 at 14:07:53 from (99.167.208.219):
In Reply to: hard starting IH 560 posted by Russ Goebel on October 01, 2008 at 12:47:56:
Well One thing to check here is the manifold bolts and make sure they are tight or remove the intake and exhaust and replace the gskt along with having the manifold milled so it is nice and flat to make sure the gskt. seal well . Then keep a check on the bolts as they will loosen up from time to time . Next do a good tune up on her along with a valve adjustment BY THE BOOK.Then put a timing lite on it and set the timing and that sets at rated PTO speed . as for gas dripping out of the carb one has to keep in mind that this is and UP DRAFT carb. and what goes up must come down . Now not saying that ya don't have a needle and seat problem but if it is only a few drops and not a steady run then this is normal on any updraft.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
