I broke a bull pinion cage on my M once doing the very same thing you describe. That was a hard-learned lesson. In any case, I'm going to try working thru the PTO. I ought to be able to pull the axle out, and once I get the bull gear loose I can pull the cage also if it's bad.
This weekend, I'll get that wheel in the air and try to locate the bad bearing. I'm almost positive it's either the inner or outer rear axle bearing. It's a fairly slow popping noise, that'll actually go away.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
