Re: m pto speed
Posted by Steven f/AZ on October 02, 2008 at 07:16:38 from (216.67.213.217):
In Reply to: m pto speed posted by ckfarmall on October 01, 2008 at 20:42:04:
It depends on how the governor is set - after 50+ years who knows how many people have messed with the max RPM setting!
Under a good load, full throttle should give 540. Since the auger isn't that much of a load you should be able to cut back a bit.
Get a hand-held tach if you want to be sure.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
