Posted by 56Utility on October 05, 2008 at 19:56:18 from (65.54.154.118):
I have a 56 300 Utility and I just purchased another one. The second tractor is serial number 28584 SJ. However, this tractor has four things that make it seem like a 350. 1) It has a c-175 engine. 2) the clutch pedal is attached from the front, not the rear. 3) the fast hitch cylinder is mounted vertically, not beside the seat.4) The steering wheel is plastic. My question is: Does anyone else have a tractor with a 300 serial number and these 350 features?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
