Re: IH 474 - good tractor?
Posted by 495man on October 16, 2008 at 13:38:06 from (24.222.9.184):
In Reply to: IH 474 - good tractor? posted by Jason from MI on October 16, 2008 at 05:33:08:
These are basically a 574 fitted with the D206 4cyl diesel, instead of a D239. IIRC they were 48 PTO HP, intended to fit between the 454 and 574.
For what it is worth, the 584 @ 52 PTO has the same engine and is basically a newer version of the 474.
The 484 did not replace the 474 contrary to what should make sense.
A 484 did not use a Perkins Engine....the D179 is a 3cyl IH german engine.
The D206 and D239 are the same engine family as the D179.
Here is one:
third party image
This post was edited by 495man at 13:39:42 10/16/08.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
