Posted by TX656 on October 20, 2008 at 02:24:57 from (71.48.164.117):
In Reply to: why low ash posted by bunghammer on October 18, 2008 at 15:21:44:
Those with the IH gas engines requiring low ash:
Are you using a low ash diesel oil as a substitue?
Is it bad to use diesel oil?
Are you using a low ash gas only oil instead?
Other?
My gas 656 has about 4400 hundred hours on it (might be 4,800 I forget, bought it used about two years ago) and suspect it had burned valves when I got it. Needs a top end and rings soon and curious as to convenient place to get low ash oil.
If I keep running it until it no longer has the power to do what I need (aside for the obvious inconvenience of failure during hay season) what kind of additional damage can I do to it working it with bad valves and bad rings. Sometimes uses 1.5-2 quarts of oil per hour of round baling or disking. Let's just say mosquitoes usually aren't a problem.
I've just been feeding it Walmart's house brand. Thanks for any input.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
