Posted by Pete in Holland, MI on October 21, 2008 at 15:50:37 from (24.247.182.9):
Guys -
Recently purchased 1939 F-20 has a missing problem. Every 1-5 seconds, the engine misses several firings in a row, then resumes with no hesitation/coughing or smoking. Not like a spark plug missing occasionally , but someone turning off & on the engine. Diagnosis has revealed these clues:
1) Each time the engine misses, a "gasp" can be heard from the carburator with the air filter hose removed.
2) Compression tests show dry results at 55-60, and wet results 55-60, across the board.
3) Spark plugs are clean & set right. Wires are almost new. Cleaned the fiber gear in the mag an cleaned the distributor brushes. The fiber gear does have about a 1/16" groove created by the brushes.
4) Carb has been adjusted lean & rich with little change.
5) More predominant at higher speeds. Less predominate at slow speed and spark retarded.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
